跳转到主内容
LG VX5300 outer LCD screen replacement
你所需要的
  1. LG VX5300 outer LCD screen replacement, Front LCD Screen: 步骤 1 中的图像 1,1
    • Remove the rubber stoppers from the four corners of the front screen.
  2. LG VX5300 outer LCD screen replacement: 步骤 2 中的图像 1,1
    • Using the Phillips screwdriver, carefully remove all four screws.
  3. LG VX5300 outer LCD screen replacement: 步骤 3 中的图像 1,2 LG VX5300 outer LCD screen replacement: 步骤 3 中的图像 2,2
    • To pry open the face plate, place the iFixit Opener tool in the crease of the phone.
  4. LG VX5300 outer LCD screen replacement, LCD Screen: 步骤 4 中的图像 1,2 LG VX5300 outer LCD screen replacement, LCD Screen: 步骤 4 中的图像 2,2
    • Carefully lift off the black frame around the LCD screen and set it aside.
  5. LG VX5300 outer LCD screen replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Lift the speaker out by using tweezers.
    • Next, lift the battery out using the tweezers.
  6. LG VX5300 outer LCD screen replacement: 步骤 6 中的图像 1,1
    • Using tweezers, carefully disconnect the orange ribbon from the computer chip.
  7. LG VX5300 outer LCD screen replacement: 步骤 7 中的图像 1,1
    • Remove the LCD screen and replace with a new one.
    • Finally, replace the battery and the speaker.
结论
Ashley
于02/12/13注册
16 声望
创作了3篇指南
团队
Ohio State, Team 1-1, Buehl Spring 2013 Ohio State, Team 1-1, Buehl Spring 2013 的会员
OSU-BUEHL-S13S1G1
3 名成员
创作了4篇指南
1指南评论
Thanks for the instructions. By chance, do you know how to replace the motherboard? Where is the mother board
Sula Tremaine - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 620
