跳转到主内容
LG VX5300 Keypad Replacement
你所需要的
  1. LG VX5300 Keypad Replacement, Disassembling Back Cover: 步骤 1 中的图像 1,3 LG VX5300 Keypad Replacement, Disassembling Back Cover: 步骤 1 中的图像 2,3 LG VX5300 Keypad Replacement, Disassembling Back Cover: 步骤 1 中的图像 3,3
    • Carefully slide battery cover off in a downward direction.
    • Using the plastic opening tool, remove the battery. Light force may be necessary.
  2. LG VX5300 Keypad Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
  3. LG VX5300 Keypad Replacement: 步骤 3 中的图像 1,1
    • Using the plastic opening tool, carefully lift the back cover off.
  4. LG VX5300 Keypad Replacement, Keypad: 步骤 4 中的图像 1,2 LG VX5300 Keypad Replacement, Keypad: 步骤 4 中的图像 2,2
    • Before touching anything inside the phone: it is crucial that you are very cautious when working around the wiring and sensor bars.
    • Look to the following photo for the location of the two sensor bars.
    • Without disconnecting the orange wire, carefully flip the computer chip over and lay flat on the table, exposing the keypad.
  5. LG VX5300 Keypad Replacement: 步骤 5 中的图像 1,2 LG VX5300 Keypad Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the keypad and replace with the new keypad.
    • If sensor bars behind the volume and camera buttons fall out, gently put them back in place behind the buttons.
  6. LG VX5300 Keypad Replacement: 步骤 6 中的图像 1,1
    • Carefully set the computer chip back in place.
  7. LG VX5300 Keypad Replacement: 步骤 7 中的图像 1,2 LG VX5300 Keypad Replacement: 步骤 7 中的图像 2,2
    • Place the back cover back on and secure it with the screws.
  8. LG VX5300 Keypad Replacement: 步骤 8 中的图像 1,2 LG VX5300 Keypad Replacement: 步骤 8 中的图像 2,2
    • Insert the battery.
    • Slide the back cover on the phone.
终点
Ashley
于02/12/13注册
13 声望
创作了3篇指南
团队
Ohio State, Team 1-1, Buehl Spring 2013 Ohio State, Team 1-1, Buehl Spring 2013 的会员
OSU-BUEHL-S13S1G1
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 575
