跳转到主内容
LG VX5200 motherboard replacement
你所需要的
  1. LG VX5200 motherboard replacement, Battery: 步骤 1 中的图像 1,2 LG VX5200 motherboard replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the phone on its back.
  2. LG VX5200 motherboard replacement: 步骤 2 中的图像 1,2 LG VX5200 motherboard replacement: 步骤 2 中的图像 2,2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 motherboard replacement: 步骤 3 中的图像 1,2 LG VX5200 motherboard replacement: 步骤 3 中的图像 2,2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 motherboard replacement, LG VX5200 Rear Body Panel Disassembly: 步骤 4 中的图像 1,1
    • Orient the phone as shown with the battery already removed.
  5. LG VX5200 motherboard replacement: 步骤 5 中的图像 1,3 LG VX5200 motherboard replacement: 步骤 5 中的图像 2,3 LG VX5200 motherboard replacement: 步骤 5 中的图像 3,3
    • Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
    • Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
  6. LG VX5200 motherboard replacement: 步骤 6 中的图像 1,3 LG VX5200 motherboard replacement: 步骤 6 中的图像 2,3 LG VX5200 motherboard replacement: 步骤 6 中的图像 3,3
    • Place an iPod opener tool in the seam above the antenna.
    • Run the tool around the perimeter of the entire phone.
  7. LG VX5200 motherboard replacement: 步骤 7 中的图像 1,1
    • Check to see that your device looks like the attached photo.
  8. LG VX5200 motherboard replacement, main board: 步骤 8 中的图像 1,3 LG VX5200 motherboard replacement, main board: 步骤 8 中的图像 2,3 LG VX5200 motherboard replacement, main board: 步骤 8 中的图像 3,3
    • Locate the tabs that hold the logic board in place.
    • Pull the outer frame of the phone outwards to release the board from the tabs.
  9. LG VX5200 motherboard replacement: 步骤 9 中的图像 1,3 LG VX5200 motherboard replacement: 步骤 9 中的图像 2,3 LG VX5200 motherboard replacement: 步骤 9 中的图像 3,3
    • Locate the copper connection (orange-colored) on the back of the board.
    • Pry the connector free from the board with your fingernail.
  10. LG VX5200 motherboard replacement: 步骤 10 中的图像 1,1
    • Check to see that your device looks like the image shown.
    • Note: The image is shown with the LCD screen removed. This is not necessary for logic board removal.
结论
2等其他人完成本指南。
团队
Cal Poly, Team 4-13, Forte Winter 2010 Cal Poly, Team 4-13, Forte Winter 2010 的会员
CPSU-FORTE-W10S4G13
5 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 2,709
