跳转到主内容
LG VX5200 Screen Replacement
你所需要的
  1. LG VX5200 Screen Replacement, Screen: 步骤 1 中的图像 1,3 LG VX5200 Screen Replacement, Screen: 步骤 1 中的图像 2,3 LG VX5200 Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Pry the grey pieces of plastic off the corners of the screen with a spudger.
  2. LG VX5200 Screen Replacement: 步骤 2 中的图像 1,2 LG VX5200 Screen Replacement: 步骤 2 中的图像 2,2
    • Unscrew each of the four screws with a Phillips #00 Screwdriver.
    • These screws are the same size as the ones from the back casing, but are not the same size as the screw from the antenna.
  3. LG VX5200 Screen Replacement: 步骤 3 中的图像 1,2 LG VX5200 Screen Replacement: 步骤 3 中的图像 2,2
    • Close the phone after removing the screws.
    • Slide a spudger into the cracks in the top half of the phone's casing.
    • Wedge and lever the spudger to remove the casing.
    • Apply constant pressure to avoid cracking the plastic casing. This step can take a few minutes.
  4. LG VX5200 Screen Replacement: 步骤 4 中的图像 1,3 LG VX5200 Screen Replacement: 步骤 4 中的图像 2,3 LG VX5200 Screen Replacement: 步骤 4 中的图像 3,3
    • Remove the chipboard from the screen by sliding a plastic spudger under the screen and lifting.
    • Use a plastic spudger to avoid short-circuiting the phone's electronics.
    • Gently lift the speaker out of the plastic casing using a plastic spudger.
    • Remove the small battery adjacent to the speaker with a plastic spudger.
  5. LG VX5200 Screen Replacement: 步骤 5 中的图像 1,3 LG VX5200 Screen Replacement: 步骤 5 中的图像 2,3 LG VX5200 Screen Replacement: 步骤 5 中的图像 3,3
    • Slide and lever a plastic spudger between the screen and it's housing.
    • Avoid tearing the wires connecting the screen, the small battery and the speaker.
    • Remove the chip connecting the screen to the camera using your fingers.
结论
jmarcum
于10/28/09注册
16 声望
撰写一个指南
团队
Cal Poly, Team 9-18, Regan Fall 2009 Cal Poly, Team 9-18, Regan Fall 2009 的会员
CPSU-REGAN-F09S9G18
5 名成员
创作了2篇指南
一条评论
The “battery” beside the speaker isn’t the battery, it’s the phone vibrator. Still a good guide, however
Kaleb White - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 3,392
