跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
LG VX5200 Rear Body Panel Disassembly
你所需要的
  1. LG VX5200 Rear Body Panel Disassembly, Battery: 步骤 1 中的图像 1,2 LG VX5200 Rear Body Panel Disassembly, Battery: 步骤 1 中的图像 2,2
    • Turn the phone on its back.
  2. LG VX5200 Rear Body Panel Disassembly: 步骤 2 中的图像 1,2 LG VX5200 Rear Body Panel Disassembly: 步骤 2 中的图像 2,2
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 Rear Body Panel Disassembly: 步骤 3 中的图像 1,2 LG VX5200 Rear Body Panel Disassembly: 步骤 3 中的图像 2,2
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 Rear Body Panel Disassembly, LG VX5200 Rear Body Panel Disassembly: 步骤 4 中的图像 1,1
    • Orient the phone as shown with the battery already removed.
  5. LG VX5200 Rear Body Panel Disassembly: 步骤 5 中的图像 1,3 LG VX5200 Rear Body Panel Disassembly: 步骤 5 中的图像 2,3 LG VX5200 Rear Body Panel Disassembly: 步骤 5 中的图像 3,3
    • Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
    • Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
  6. LG VX5200 Rear Body Panel Disassembly: 步骤 6 中的图像 1,3 LG VX5200 Rear Body Panel Disassembly: 步骤 6 中的图像 2,3 LG VX5200 Rear Body Panel Disassembly: 步骤 6 中的图像 3,3
    • Place an iPod opener tool in the seam above the antenna.
    • Run the tool around the perimeter of the entire phone.
  7. LG VX5200 Rear Body Panel Disassembly: 步骤 7 中的图像 1,1
    • Check to see that your device looks like the attached photo.
结论
团队
Cal Poly, Team 4-13, Forte Winter 2010 Cal Poly, Team 4-13, Forte Winter 2010 的会员
CPSU-FORTE-W10S4G13
5 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 3,231
