当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
Check to see that your device looks like the image shown.
Do not let the buttons fall out of the side casing of the phone!
Note: The image is shown with the LCD screen removed. This is not necessary for keypad repair.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
