当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn the phone on its back.
Orient the phone as shown.
Remove the battery cover by pushing upward with your thumb.
Place your fingernail at the top of the battery and pry the battery out towards you.
Orient the phone as shown with the battery already removed.
Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
Place an iPod opener tool in the seam above the antenna.
Run the tool around the perimeter of the entire phone.
Check to see that your device looks like the attached photo.
Locate the screw and copper fixture that hold the antenna in place.
Remove the screw from the device using a Philips #00 screwdriver.
Remove the copper fixture after it has been unscrewed.
取消:我没有完成这个指南。
与6其他贡献者
于01/13/10注册
282 声望
创作了8篇指南
徽章: 13
+ 10更多徽章
CPSU-FORTE-W10S4G13
5 名成员
创作了15篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 16
总计 2,453
