跳转到主内容
LG VX4500 screen replacement (duplicate)
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. LG VX4500 screen replacement (duplicate), Speaker: 步骤 1 中的图像 1,2 LG VX4500 screen replacement (duplicate), Speaker: 步骤 1 中的图像 2,2
    • Remove grey rubber caps from the four corners of the internal screen.
    • Remove the four 1.3 mm screws, which are directly underneath the grey caps, with a Phillips head screwdriver.
  2. LG VX4500 screen replacement (duplicate): 步骤 2 中的图像 1,3 LG VX4500 screen replacement (duplicate): 步骤 2 中的图像 2,3 LG VX4500 screen replacement (duplicate): 步骤 2 中的图像 3,3
    • Run a pry bar along the seem of the edge of the phone to separate the top screen casing.
    • Work the bar around the edge until the entire top section with the LG logo is removed.
  3. LG VX4500 screen replacement (duplicate): 步骤 3 中的图像 1,3 LG VX4500 screen replacement (duplicate): 步骤 3 中的图像 2,3 LG VX4500 screen replacement (duplicate): 步骤 3 中的图像 3,3
    • With a flathead screwdriver, lift the speaker from the device.
  4. LG VX4500 screen replacement (duplicate), Internal and External Screen: 步骤 4 中的图像 1,3 LG VX4500 screen replacement (duplicate), Internal and External Screen: 步骤 4 中的图像 2,3 LG VX4500 screen replacement (duplicate), Internal and External Screen: 步骤 4 中的图像 3,3
    • Ensure that the metal capacitor next to the speaker is removed in the same way that the speaker was removed.
    • Gently lift the entire circuit board assembly up.
    • Note: the entire assembly is still connected to the phone.
  5. LG VX4500 screen replacement (duplicate): 步骤 5 中的图像 1,2 LG VX4500 screen replacement (duplicate): 步骤 5 中的图像 2,2
    • Desolder the contact point shown.
    • Gently pry the entire gold connector away from the screen with a spudger
结论
iDeleted
于07/07/10注册
2,101 声望
创作了39篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 198
