跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Replacing the speaker.
  1. Turn the closed phone so that the back panel is facing you.
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. Now just lift up on the battery and remove it from the phone. Now just lift up on the battery and remove it from the phone.
    • Now just lift up on the battery and remove it from the phone.
  3. Remove the rubber grommet using a Spudger.
    • Remove the rubber grommet using a Spudger.
  4. 基本电子产品工具包
    小工具包。却有无限可能。
    Shop Toolkits
    基本
    电子产品
    工具包
    Shop Toolkits
  5. Be sure not to lose the screws. They are small!
    • Be sure not to lose the screws. They are small!
    • Remove the five screws using a Phillips #00 Screwdriver.
  6. When removing back cover, be careful not to break the speaker wires. Using an iPod Opening Tool, carefully pry off the back cover. Using Tweezers, gently pull speaker wires out.
    • When removing back cover, be careful not to break the speaker wires.
    • Using an iPod Opening Tool, carefully pry off the back cover.
    • Using Tweezers, gently pull speaker wires out.
  7. Separate the two halves.
    • Separate the two halves.
  8. Take top half of phone and pry up speaker using the Spudger. Take top half of phone and pry up speaker using the Spudger.
    • Take top half of phone and pry up speaker using the Spudger.
  9. Lift out speaker.
    • Lift out speaker.
结论
David Foster
于2010年04月11日注册
1 信誉积分
创作了8篇指南
团队
Cal Poly, Team 25-88, Amido Spring 2010 Cal Poly, Team 25-88, Amido Spring 2010 的会员
CPSU-AMIDO-S10S25G88
4 名成员
创作了18篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,883
