跳转到主内容
加入维修社区 - 创建账户
LG VX4500 Disassembly
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. LG VX4500 Disassembly, Battery: 步骤 1 中的图像 1,1
    • Before removing the battery, ensure that the phone is turned off.
    • To remove the battery from your LG VX4500, turn the phone so that the back panel is showing.
  2. LG VX4500 Disassembly: 步骤 2 中的图像 1,1
    • Pull back on the white release tab and lift up the the entire battery.
  3. LG VX4500 Disassembly: 步骤 3 中的图像 1,1
    • The back panel should now be fully accessible.
  4. LG VX4500 Disassembly, LG VX4500 Disassembly: 步骤 4 中的图像 1,2 LG VX4500 Disassembly, LG VX4500 Disassembly: 步骤 4 中的图像 2,2
    • Using a paper clip, remove all 4 rubber screwcaps from the screw ports.
    • With a Phillips head screwdriver, remove all 4 screws from their ports.
    • Also remove the rubber screwcap in the upper part of the back panel along with the screw under it.
    • The fifth screw will be more difficult to get out because the plastic port has much higher sides.
  5. LG VX4500 Disassembly: 步骤 5 中的图像 1,3 LG VX4500 Disassembly: 步骤 5 中的图像 2,3 LG VX4500 Disassembly: 步骤 5 中的图像 3,3
    • Run a plastic opening tool along the seam to seperate the keyboard cover and the back panel
    • Remove the back panel, now the logic board, keyboard and microphone are exposed.
结论
iDeleted
于07/07/10注册
2,101 声望
创作了39篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 4,443
