跳转到主内容
LG VX4400 Removing the Back Cover
你所需要的
  1. LG VX4400 Removing the Back Cover, Battery: 步骤 1 中的图像 1,3 LG VX4400 Removing the Back Cover, Battery: 步骤 1 中的图像 2,3 LG VX4400 Removing the Back Cover, Battery: 步骤 1 中的图像 3,3
    • Press the light grey button in the top-center on the back of the phone.
    • While pressing, slide the battery and cover up.
  2. LG VX4400 Removing the Back Cover, Antenna: 步骤 2 中的图像 1,1
    • Unscrew the antenna by grasping the base and twisting counterclockwise.
    • The antenna may separate from a black sleeve during removal. You may need to use tweezers to remove the sleeve. Remove both the antenna and the sleeve and set aside.
  3. LG VX4400 Removing the Back Cover, LG VX4400 Removing the Back Cover: 步骤 3 中的图像 1,3 LG VX4400 Removing the Back Cover, LG VX4400 Removing the Back Cover: 步骤 3 中的图像 2,3 LG VX4400 Removing the Back Cover, LG VX4400 Removing the Back Cover: 步骤 3 中的图像 3,3
    • The phone may have a rubber insert in the bottom of the phone (see picture). If this rubber insert exists, remove it from the bottom of phone and set aside.
  4. LG VX4400 Removing the Back Cover: 步骤 4 中的图像 1,2 LG VX4400 Removing the Back Cover: 步骤 4 中的图像 2,2
    • Use a Torx T6 screwdriver to unscrew the four screws on the back of the phone.
    • The bit size is engraved on the base of the bit head.
  5. LG VX4400 Removing the Back Cover: 步骤 5 中的图像 1,3 LG VX4400 Removing the Back Cover: 步骤 5 中的图像 2,3 LG VX4400 Removing the Back Cover: 步骤 5 中的图像 3,3
    • With the phone flipped open, wedge the back cover from the faceplate by running the tip of the plastic opening tool around the seam on the back of the phone.
    • Gently pull the two pieces apart to separate, and set the back casing aside.
    • Apply enough force to separate the pieces without cracking the back cover.
  6. LG VX4400 Removing the Back Cover: 步骤 6 中的图像 1,1
    • Lift the motherboard to gain access to the keypad and side buttons beneath.
    • The motherboard is attached with a thin ribbon cable at the upper right corner of the case. Be careful not to break the cable.
结论
<b>To reassemble your device, follow these instructions in reverse order.</b>
Nico Chiarito
于01/21/10注册
22 声望
创作了5篇指南
团队
Cal Poly, Team 8-47, Regan Winter 2010 Cal Poly, Team 8-47, Regan Winter 2010 的会员
CPSU-REGAN-W10S8G47
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 2,552
