跳转到主内容
LG VX3100 Keypad Replacement
你所需要的
  1. LG VX3100 Keypad Replacement, Battery: 步骤 1 中的图像 1,2 LG VX3100 Keypad Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn off the cellphone by pressing down on the red "END" button for 3 seconds.
    • Flip cellphone over and press up on the gray sliding mechanism towards the top of the phone. At the same time, pull on the large silver battery and it should come right off.
  2. LG VX3100 Keypad Replacement, Keypad: 步骤 2 中的图像 1,1
    • Use a T7 Torx screwdriver to remove the four screws that are located underneath the area where the battery was.
  3. LG VX3100 Keypad Replacement: 步骤 3 中的图像 1,3 LG VX3100 Keypad Replacement: 步骤 3 中的图像 2,3 LG VX3100 Keypad Replacement: 步骤 3 中的图像 3,3
    • Be careful when removing the casing as the spudger can damage the plastic cover of the phone.
    • Use the spudger to carefully pry around the sides of the plastic casing and remove the back side of the phone.
  4. LG VX3100 Keypad Replacement: 步骤 4 中的图像 1,3 LG VX3100 Keypad Replacement: 步骤 4 中的图像 2,3 LG VX3100 Keypad Replacement: 步骤 4 中的图像 3,3
    • Use the spudger to remove the back side of the phone.
    • The logic board is still connected to the rest of the phone with a gold strip; be careful when removing the board.
    • Use the spudger to gently push the keypad out from the other side of the phone.
结论
Tyler
于04/09/10注册
1 声望
创作了2篇指南
团队
Cal Poly, Team 34-58, Forte Spring 2010 Cal Poly, Team 34-58, Forte Spring 2010 的会员
CPSU-FORTE-S10S34G58
5 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 13
总计 2,397
