跳转到主内容
LG V30 Plus Rear Glass Replacement
你所需要的
  1. LG V30 Plus Rear Glass Replacement, Rear Glass: 步骤 1 中的图像 1,1
    • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
    • Allow to sit for 1-2 minutes to heat up the adhesive.
    • A heat gun may need to be used if you have trouble separating the backing in the next step.
  2. LG V30 Plus Rear Glass Replacement: 步骤 2 中的图像 1,2 LG V30 Plus Rear Glass Replacement: 步骤 2 中的图像 2,2
    • Insert an Opening Tool into the seam between the rear glass and side of the phone.
    • Pry the glass off just enough to insert an Opening Pick.
    • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
  3. LG V30 Plus Rear Glass Replacement: 步骤 3 中的图像 1,1
    • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
结论
Geoffrey Smith
于04/18/19注册
395 声望
创作了3篇指南
团队
Cal Poly, Team S1-G3, Maness Spring 2019 Cal Poly, Team S1-G3, Maness Spring 2019 的会员
CPSU-MANESS-S19S1G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 1,032
