跳转到主内容
加入维修社区 - 创建账户
LG V30 Plus Battery Replacement
你所需要的
  1. LG V30 Plus Battery Replacement, Rear Glass: 步骤 1 中的图像 1,1
    • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
    • Allow to sit for 1-2 minutes to heat up the adhesive.
    • A heat gun may need to be used if you have trouble separating the backing in the next step.
  2. LG V30 Plus Battery Replacement: 步骤 2 中的图像 1,2 LG V30 Plus Battery Replacement: 步骤 2 中的图像 2,2
    • Insert an Opening Tool into the seam between the rear glass and side of the phone.
    • Pry the glass off just enough to insert an Opening Pick.
    • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
  3. LG V30 Plus Battery Replacement: 步骤 3 中的图像 1,1
    • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
  4. LG V30 Plus Battery Replacement, Motherboard: 步骤 4 中的图像 1,2 LG V30 Plus Battery Replacement, Motherboard: 步骤 4 中的图像 2,2
    • Remove the ten 4mm screws using the Phillips #00 Screwdriver.
  5. LG V30 Plus Battery Replacement: 步骤 5 中的图像 1,3 LG V30 Plus Battery Replacement: 步骤 5 中的图像 2,3 LG V30 Plus Battery Replacement: 步骤 5 中的图像 3,3
    • Gently push down on the small black tab with a Spudger to release the protective board.
    • Slide an Opening Tool between the phone and the protective board and slide along the edges of the phone to unclip it.
    • Carefully wiggle the board back and forth while gently pulling to unclip the last attachment point.
  6. LG V30 Plus Battery Replacement: 步骤 6 中的图像 1,2 LG V30 Plus Battery Replacement: 步骤 6 中的图像 2,2
    • Slide an Opening Tool between the lower protective board and the phone to unclip.
    • Slide the tool along the remaining edges of the protective board until it pops off.
  7. LG V30 Plus Battery Replacement: 步骤 7 中的图像 1,2 LG V30 Plus Battery Replacement: 步骤 7 中的图像 2,2
    • Gently pry each visible ribbon cable away from the motherboard to disconnect them.
  8. LG V30 Plus Battery Replacement: 步骤 8 中的图像 1,1
    • Gently remove the motherboard from the phone.
  9. LG V30 Plus Battery Replacement, Battery: 步骤 9 中的图像 1,3 LG V30 Plus Battery Replacement, Battery: 步骤 9 中的图像 2,3 LG V30 Plus Battery Replacement, Battery: 步骤 9 中的图像 3,3
    • Use a Spudger to get between the battery and the phone and pry each edge of the battery away from the board.
    • There may be a strong adhesive under the battery, so work your way around the battery carefully and slowly.
    • Insert Opening Picks if needed to keep the battery elevated.
结论
另外一个人完成了本指南。
Samuel Jahnke
于04/22/19注册
282 声望
创作了2篇指南
团队
Cal Poly, Team S1-G3, Maness Spring 2019 Cal Poly, Team S1-G3, Maness Spring 2019 的会员
CPSU-MANESS-S19S1G3
4 名成员
创作了10篇指南
1指南评论
I did this and now my phone’s touch screen is unresponsive. The power button and volume buttons work and the phone turns on, but I cannot unlock my phone due to the touch screen not responding
Julian Marley - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 29
总计 2,289
