跳转到主内容
加入维修社区 - 创建账户
LG V20 MB Assembly Replacement
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. LG V20 MB Assembly Replacement, Battery: 步骤 1 中的图像 1,3 LG V20 MB Assembly Replacement, Battery: 步骤 1 中的图像 2,3 LG V20 MB Assembly Replacement, Battery: 步骤 1 中的图像 3,3
    • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
    • Be careful not to deform or puncture the battery.
    • Pry up and remove the battery.
  2. LG V20 MB Assembly Replacement, Midframe Assembly: 步骤 2 中的图像 1,1
    • Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
  3. LG V20 MB Assembly Replacement: 步骤 3 中的图像 1,2 LG V20 MB Assembly Replacement: 步骤 3 中的图像 2,2
    • The top and bottom frame section hold very tight to the mid frame. It is possible to pull them off with your hands. If you're not able to do so, use the following removal procedure:
    • Use the flat end of a spudger and apply pressure to one of the corners of the frame section until you create a small gap.
  4. LG V20 MB Assembly Replacement: 步骤 4 中的图像 1,2 LG V20 MB Assembly Replacement: 步骤 4 中的图像 2,2
    • Flip the phone and insert an opening pick in the gap you created.
    • Slide the opening pick along the gap until the frame section pops out of its plastic clamps.
  5. LG V20 MB Assembly Replacement: 步骤 5 中的图像 1,1
    • Remove the frame section.
    • Repeat this procedure with the frame section on the other end of the phone.
    • Within the top frame section there's a small silver grating that covers the speaker. This may fall out, so be careful not to lose it.
  6. LG V20 MB Assembly Replacement: 步骤 6 中的图像 1,2 LG V20 MB Assembly Replacement: 步骤 6 中的图像 2,2
    • The loudspeaker is attached to the cover of the motherboard. Use an opening pick to pry it up.
  7. LG V20 MB Assembly Replacement: 步骤 7 中的图像 1,2 LG V20 MB Assembly Replacement: 步骤 7 中的图像 2,2
    • The cover of the motherboard is held in its place by several plastic clamps.
    • Use an opening pick to pry up the motherboard cover at the right corner at the bottom of your phone until it pops out of the plastic clamp.
  8. LG V20 MB Assembly Replacement: 步骤 8 中的图像 1,2 LG V20 MB Assembly Replacement: 步骤 8 中的图像 2,2
    • Slide the opening pick along the mid frame and flip it sideways to open the plastic clamps holding the motherboard cover in its place.
  9. LG V20 MB Assembly Replacement: 步骤 9 中的图像 1,1
    • Remove the motherboard cover.
  10. LG V20 MB Assembly Replacement, Front-Facing Camera: 步骤 10 中的图像 1,2 LG V20 MB Assembly Replacement, Front-Facing Camera: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    • Use the flat end of a spudger to disconnect the front camera flex cable.
    • If you want to go on and remove the motherboard assembly, there is no need to remove the front facing camera after disconnecting it. However if you feel uncertain, carefully remove it with a pair of tweezers.
    • Use a pair of tweezers to carefully remove the front facing camera. Be careful to only grip the body of the camera, as the top is the sensor pcb and is only held on with glue (removal will ruin the sensor).
  11. LG V20 MB Assembly Replacement, Motherboard Assembly: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    • Use the flat end of a spudger to disconnect the flex cable of the left rear camera.
    • The second rear camera will come out with the motherboard since it is connected on the other side.
    • You can leave the front facing camera in its place as long as you're careful while removing the motherboard assembly. However if you feel uncertain, carefully remove it with a pair of tweezers.
  12. LG V20 MB Assembly Replacement: 步骤 12 中的图像 1,1
    • Disconnect the display flex cable with the flat end of a spudger.
  13. LG V20 MB Assembly Replacement: 步骤 13 中的图像 1,2 LG V20 MB Assembly Replacement: 步骤 13 中的图像 2,2
    • Use the pointed end of a spudger to lift up the motherboard assembly until you can get a good grip.
    • Carefully lift up the motherboard assembly and remove it.
结论
6等其他人完成本指南。
Max Wu
于04/26/17注册
299 声望
创作了4篇指南
3指南评论
Are the parts from the LG v20 h910 compatible with the LG V10 h900
Ryan Wolfe - 回复
I need to replace the motherboard on my LG V10 model h900 and all I have is an LG v20 model H 9100 will all the parts be compatible
Ryan Wolfe - 回复
Hello, where can I find the internal memory module for the LG V20?
enlil_ragas - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 39
总计 3,727
