跳转到主内容
LG V20 Battery Replacement
你所需要的
  1. LG V20 Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 LG V20 Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 LG V20 Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Press the button on the lower right side of the LG V20 to open the clamp that holds the back cover on the back side of the phone.
    • Remove the back cover.
  2. LG V20 Battery Replacement, Battery: 步骤 2 中的图像 1,3 LG V20 Battery Replacement, Battery: 步骤 2 中的图像 2,3 LG V20 Battery Replacement, Battery: 步骤 2 中的图像 3,3
    • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
    • Be careful not to deform or puncture the battery.
    • Pry up and remove the battery.
结论
For optimal performance and to avoid software sided errors, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%.
10等其他人完成本指南。
Garrett Janney
于04/26/17注册
897 声望
创作了4篇指南
团队
Cal Poly, Team S22-G5, Livingston Spring 2017 Cal Poly, Team S22-G5, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S22G5
4 名成员
创作了36篇指南
3条评论
Is this battery the same quality or a least pretty close to the OEM battery of the LG v20?
Allen Wong - 回复
Don’t buy this battery. It looks like an OEM but it’s not. That’s fine but I’ve had this for a couple months and it quickly discharges now. I’ve gone back to my original for the time being.
The only reason why I purchased it from here was the company which I have mad respect for. But this issue isn’t their problem and we’re talking about an old phone which LG doesn’t even make batteries for. People will still come here since it’s the last phone with easy access to the battery and it’s just a great budget phone!
Kenneth Shin - 回复
Just charged my new battery up from ifixit store. Sooo much better then my old one. (4 years old.)
Will update if there’s been an issue with it within the first year or two if i remember (i mean to.).
Happy repairing everyone!
RxMode - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 70
总计 9,267
