跳转到主内容
LG V10 Side Bumper Replacement
你所需要的
  1. LG V10 Side Bumper Replacement, Battery: 步骤 1 中的图像 1,1
    • Wedge the flat end of the plastic spudger, or the tip of your finger, in between the back cover and the LG V10’s charging port.
    • If using a spudger, it should not be in the charging port, but between the metal lining of the charging port and the back cover.
    • Carefully lift up on the spudger or with your finger so that the back cover pops up. The rest of the back cover should easily come off by sliding a finger or spudger under the back cover and around the sides.
  2. LG V10 Side Bumper Replacement: 步骤 2 中的图像 1,2 LG V10 Side Bumper Replacement: 步骤 2 中的图像 2,2
    • There’s an impression next to the battery for the user to use their finger to pry the battery out; pry the battery out using your finger or the flat end of the spudger.
  3. LG V10 Side Bumper Replacement, Motherboard: 步骤 3 中的图像 1,3 LG V10 Side Bumper Replacement, Motherboard: 步骤 3 中的图像 2,3 LG V10 Side Bumper Replacement, Motherboard: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using a screwdriver with a J000 Phillips bit, remove the fourteen 3.175 mm screws.
    • Using a plastic opening tool, pry part of the panel up starting from the sides of the battery slot.
    • Use plastic tweezers to release the rest of the panel from plastic bits holding it in place and pry the panel up around the sides surrounding the fingerprint sensor and camera lens; set the back panel off to the side.
  4. LG V10 Side Bumper Replacement: 步骤 4 中的图像 1,2 LG V10 Side Bumper Replacement: 步骤 4 中的图像 2,2
    • Carefully disconnect these two connectors by using the flat end of the plastic spudger to wedge the connectors away from the motherboard.
    • Use the plastic tweezers to pry the motherboard out from the plastic bits holding it in place.
  5. LG V10 Side Bumper Replacement, Side Bumper: 步骤 5 中的图像 1,1
    • Using a Phillips #000 screwdriver, remove the six 2 mm screws.
    • These screws are smaller than the others. Make sure to keep them separate.
  6. LG V10 Side Bumper Replacement: 步骤 6 中的图像 1,2 LG V10 Side Bumper Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Turn the phone over and orient it so the bottom faces you.
    • Use tweezers to carefully lift the bottom cover held by glue.
    • Once you pry the bottom enough, gently pull the bottom away using your hands.
  7. LG V10 Side Bumper Replacement: 步骤 7 中的图像 1,3 LG V10 Side Bumper Replacement: 步骤 7 中的图像 2,3 LG V10 Side Bumper Replacement: 步骤 7 中的图像 3,3
    • Turn the phone over to view the backside.
    • Slide the side bumper towards the bottom of the phone and pull the bumper away from the device.
    • Repeat for the other side.
结论
另外一个人完成了本指南。
Corey McDonough
于04/02/19注册
237 声望
创作了2篇指南
团队
IUPUI, Team S3-G6, Harley Spring 2019 IUPUI, Team S3-G6, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S3G6
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 184
