简介
This guide will teach you how to remove the SD card on your LG Ultimate 2. In order to remove the SD card, you will need to use a spudger in order to loosen the back of the phone. Then, you will remove the back of the phone with your hands. Finally, you will use your hand or a metal spudger to pull the SD card out of the phone.
你所需要的
Wedge the plastic opening tool into the seam between the plastic backing and the rest of the phone.
另外一个人完成了本指南。
