跳转到主内容
LG Ultimate 2 Digitizer Replacement
你所需要的
  1. LG Ultimate 2 Digitizer Replacement, Battery: 步骤 1 中的图像 1,1
    • Wedge the plastic opening tool into the seam between the plastic backing and the rest of the phone.
  2. LG Ultimate 2 Digitizer Replacement: 步骤 2 中的图像 1,1
    • Use your hand to pull the plastic cover completely off of the phone.
  3. LG Ultimate 2 Digitizer Replacement: 步骤 3 中的图像 1,1
    • Insert the plastic opening tool into the wedge near the bottom of the battery.
    • Lift the battery out.
  4. LG Ultimate 2 Digitizer Replacement, Digitizer: 步骤 4 中的图像 1,2 LG Ultimate 2 Digitizer Replacement, Digitizer: 步骤 4 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the 11 mid-frame screws.
  5. LG Ultimate 2 Digitizer Replacement: 步骤 5 中的图像 1,2 LG Ultimate 2 Digitizer Replacement: 步骤 5 中的图像 2,2
    • Insert the plastic opening tool to start wedging the phone apart.
    • Trace the plastic opening tool along the edge for the entire perimeter of the phone, pulling it apart as you go.
  6. LG Ultimate 2 Digitizer Replacement: 步骤 6 中的图像 1,1
    • Use a plastic opening tool or fingernail to separate the zip connector.
    • The zip connector does not detach completely from the phone, but acts as a flap.
  7. LG Ultimate 2 Digitizer Replacement: 步骤 7 中的图像 1,1
    • Insert the plastic opening tool between the screen and the base. This may be difficult because of the adhesive, but enough leverage should force an opening.
  8. LG Ultimate 2 Digitizer Replacement: 步骤 8 中的图像 1,1
    • Continue moving the plastic opening tool along the edge of the screen, separating the pieces from the adhesive.
    • A hair dryer might be useful to help melt the adhesive.
  9. LG Ultimate 2 Digitizer Replacement: 步骤 9 中的图像 1,1
    • Pry the screen off after all pieces have been loosened from the adhesive.
结论
Devin Isenhower
于03/21/18注册
329 声望
创作了2篇指南
团队
IUPUI, Team S5-G2, Baechle Spring 2018 IUPUI, Team S5-G2, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S5G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 388
