跳转到主内容
LG Tribute Rear-Facing Camera Replacement
你所需要的
  1. LG Tribute Rear-Facing Camera Replacement, Battery: 步骤 1 中的图像 1,2 LG Tribute Rear-Facing Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Use the plastic opening tool to pry off the back cover.
  2. LG Tribute Rear-Facing Camera Replacement: 步骤 2 中的图像 1,1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. LG Tribute Rear-Facing Camera Replacement, Mid-panel: 步骤 3 中的图像 1,2 LG Tribute Rear-Facing Camera Replacement, Mid-panel: 步骤 3 中的图像 2,2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  4. LG Tribute Rear-Facing Camera Replacement: 步骤 4 中的图像 1,2 LG Tribute Rear-Facing Camera Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  5. LG Tribute Rear-Facing Camera Replacement, Rear Facing Camera: 步骤 5 中的图像 1,2 LG Tribute Rear-Facing Camera Replacement, Rear Facing Camera: 步骤 5 中的图像 2,2
    • Disconnect the rear facing camera from the motherboard using a plastic opening tool.
    • Lift the rear facing camera out of its housing.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 639
