跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide will teach you how to properly replace the headphones jack in the LG Tribute HD LS676.
  1. Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove. Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
    • Insert a fingernail, or plastic opening tool, into the cutout on the back cover and pry outward to remove.
  2. Pull the battery out of the phone. Remove the SD Card by sliding the card out as shown.
    • Pull the battery out of the phone.
    • Remove the SD Card by sliding the card out as shown.
  3. Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
    Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
  4. Remove the twelve 2mm JIS #00 screws from the mid-frame. Remove the twelve 2mm JIS #00 screws from the mid-frame.
    • Remove the twelve 2mm JIS #00 screws from the mid-frame.
  5. Using a plastic opening tool, remove the antenna extender from the mid-frame. Using a plastic opening tool, remove the antenna extender from the mid-frame. Using a plastic opening tool, remove the antenna extender from the mid-frame.
    • Using a plastic opening tool, remove the antenna extender from the mid-frame.
  6. Using your fingers, remove the mid-frame. Using your fingers, remove the mid-frame.
    • Using your fingers, remove the mid-frame.
  7. Use plastic opening tool to pry up the flex cable from the back panel. Flip over and push on the back side of the headphone jack to dislodge it. Flip over and push on the back side of the headphone jack to dislodge it.
    • Use plastic opening tool to pry up the flex cable from the back panel.
    • Flip over and push on the back side of the headphone jack to dislodge it.
结论
Jerry Koenig
于2018年02月14日注册
661 信誉积分
创作了4篇指南
团队
USF Tampa, Team S1-G3, Nance Spring 2018 USF Tampa, Team S1-G3, Nance Spring 2018 的会员
USFT-NANCE-S18S1G3
4 名成员
创作了10篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 5
过去的30天: 11
总计 486
