跳转到主内容
LG Tribute 5 Motherboard Replacement
你所需要的
  1. LG Tribute 5 Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 LG Tribute 5 Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Using an iFixit opening tool, gently pull outward on the cutout on the bottom left corner of the phone to remove the back cover.
  2. LG Tribute 5 Motherboard Replacement: 步骤 2 中的图像 1,3 LG Tribute 5 Motherboard Replacement: 步骤 2 中的图像 2,3 LG Tribute 5 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Gently lift the battery out from the compartment.
    • Use an iFixit opening tool to slide out the SD card and nano sim card from the device as shown.
  3. LG Tribute 5 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,3 LG Tribute 5 Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,3 LG Tribute 5 Motherboard Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Remove the nine 2mm JIS #00 screws from the mid-frame.
  4. LG Tribute 5 Motherboard Replacement: 步骤 4 中的图像 1,3 LG Tribute 5 Motherboard Replacement: 步骤 4 中的图像 2,3 LG Tribute 5 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Using an iFixit opening tool, remove the antenna extender located at the bottom.
  5. LG Tribute 5 Motherboard Replacement: 步骤 5 中的图像 1,2 LG Tribute 5 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Gently remove the mid-frame using an iFixit opening tool as shown.
    • Avoid applying too much force when separating the mid frame. Too much force can bend or damage the device.
  6. LG Tribute 5 Motherboard Replacement: 步骤 6 中的图像 1,2 LG Tribute 5 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Using an iFixit opening tool, gently disconnect the rear camera from the top center of the motherboard.
    • Remove the front facing camera from the top right corner of the motherboard.
  7. LG Tribute 5 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Gently pull the speaker out from its compartment with the iFixit opening tool.
  8. LG Tribute 5 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Disconnect the flex cable from the motherboard with the iFixit opening tool.
  9. LG Tribute 5 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Gently pull up and remove the motherboard using the iFixit opening tool.
结论
4等其他人完成本指南。
团队
UW Tacoma, Team S1-G6, Cardinal Spring 2019 UW Tacoma, Team S1-G6, Cardinal Spring 2019 的会员
UWT-CARDINAL-S19S1G6
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 408
