跳转到主内容
LG Treasure Rear Camera Replacement
你所需要的
  1. LG Treasure Rear Camera Replacement, Battery: 步骤 1 中的图像 1,2 LG Treasure Rear Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the LG Treasure is turned off.
    • Pull off the back cover from the phone using the groove on the bottom right side.
  2. LG Treasure Rear Camera Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the phone by lifting up on the bottom end of the battery.
  3. LG Treasure Rear Camera Replacement, Rear Camera: 步骤 3 中的图像 1,2 LG Treasure Rear Camera Replacement, Rear Camera: 步骤 3 中的图像 2,2
    • Remove all 9 of the 3 mm Phillips #000 screws from the digitizer.
    • Work your way around the edge of the phone, gently prying the digitizer off the phone.
  4. LG Treasure Rear Camera Replacement: 步骤 4 中的图像 1,2 LG Treasure Rear Camera Replacement: 步骤 4 中的图像 2,2
    • Pull up on the gold film-like connector which is to the left side of camera. Once you have pulled the connector loose you can then gently lift the rear camera out of the phone.
结论
2等其他人完成本指南。
团队
UW Stout, Team S8-G5, Ogden Spring 2018 UW Stout, Team S8-G5, Ogden Spring 2018 的会员
UWSTOUT-OGDEN-S18S8G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 7
总计 301
