跳转到主内容
LG Treasure Auxiliary Port Replacement
你所需要的
  1. LG Treasure Auxiliary Port Replacement, Battery: 步骤 1 中的图像 1,2 LG Treasure Auxiliary Port Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the LG Treasure is turned off.
    • Pull off the back cover from the phone using the groove on the bottom right side.
  2. LG Treasure Auxiliary Port Replacement: 步骤 2 中的图像 1,1
    • Remove the battery from the phone by lifting up on the bottom end of the battery.
  3. LG Treasure Auxiliary Port Replacement, Auxiliary Port: 步骤 3 中的图像 1,2 LG Treasure Auxiliary Port Replacement, Auxiliary Port: 步骤 3 中的图像 2,2
    • Remove all 9 of the 3mm Phillips #000 screws from the digitizer.
    • Work your way around the edge of the phone, gently prying the digitizer off the phone.
  4. LG Treasure Auxiliary Port Replacement: 步骤 4 中的图像 1,3 LG Treasure Auxiliary Port Replacement: 步骤 4 中的图像 2,3 LG Treasure Auxiliary Port Replacement: 步骤 4 中的图像 3,3
    • Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out.
结论
另外一个人完成了本指南。
团队
UW Stout, Team S8-G5, Ogden Spring 2018 UW Stout, Team S8-G5, Ogden Spring 2018 的会员
UWSTOUT-OGDEN-S18S8G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 323
