简介
This guide will explain how to replace the Auxiliary Port (headphone jack) on the LG Treasure.
配件
无需配件。
  1. Make sure the LG Treasure is turned off. Pull off the back cover from the phone using the groove on the bottom right side.
    • Make sure the LG Treasure is turned off.
    • Pull off the back cover from the phone using the groove on the bottom right side.
  2. Remove the battery from the phone by lifting up on the bottom end of the battery.
    • Remove the battery from the phone by lifting up on the bottom end of the battery.
  3. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Remove all 9 of the 3mm Phillips #000 screws from the digitizer. Work your way around the edge of the phone, gently prying the digitizer off the phone.
    • Remove all 9 of the 3mm Phillips #000 screws from the digitizer.
    • Work your way around the edge of the phone, gently prying the digitizer off the phone.
  5. Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out. Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out. Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out.
    • Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out.
结论
另外一个人完成了本指南。
david amirahmadi
于2018年02月15日注册
537 信誉积分
创作了5篇指南
团队
UW Stout, Team S8-G5, Ogden Spring 2018 UW Stout, Team S8-G5, Ogden Spring 2018 的会员
UWSTOUT-OGDEN-S18S8G5
3 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 6
总计 103
