跳转到主内容
LG Tone Pro HBS-770 Speaker Replacement
你所需要的
  1. LG Tone Pro HBS-770 Speaker Replacement, Locate Hidden Screw: 步骤 1 中的图像 1,3 LG Tone Pro HBS-770 Speaker Replacement, Locate Hidden Screw: 步骤 1 中的图像 2,3 LG Tone Pro HBS-770 Speaker Replacement, Locate Hidden Screw: 步骤 1 中的图像 3,3
    • There are 2 hidden screws that need to be removed.
    • Remove the rubber covering that covers the hidden screws.
  2. LG Tone Pro HBS-770 Speaker Replacement, Remove Hidden Screws: 步骤 2 中的图像 1,2 LG Tone Pro HBS-770 Speaker Replacement, Remove Hidden Screws: 步骤 2 中的图像 2,2
    • Remove both of the hidden screws using a Philips #00 screwdriver.
  3. LG Tone Pro HBS-770 Speaker Replacement, Pry Open Housing: 步骤 3 中的图像 1,3 LG Tone Pro HBS-770 Speaker Replacement, Pry Open Housing: 步骤 3 中的图像 2,3 LG Tone Pro HBS-770 Speaker Replacement, Pry Open Housing: 步骤 3 中的图像 3,3
    • Use a guitar pick or any pry opening tool to open the housing.
  4. LG Tone Pro HBS-770 Speaker Replacement, Remove Speaker: 步骤 4 中的图像 1,1
    • Desolder speaker connection from board using a solder iron.
结论
7等其他人完成本指南。
Faizan Naveed
于04/12/17注册
3,294 声望
创作了8篇指南
团队
Mobile Device Repair Factory Mobile Device Repair Factory 的会员
Business
1 名成员
创作了16篇指南
3条评论
where do you get the parts
Blaize Lucas - 回复
where to you get the replacement part
Blaize Lucas - 回复
Cannibalize another headphone set typically one that is wired and steal the wires from it to replace the worn ones assuming the original speakers aren't blown
michaelwilkins437 -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 2,352
