跳转到主内容
LG Tone Pro HBS-760 Speaker Replacement
你所需要的
  1. LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: 步骤 1 中的图像 1,3 LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: 步骤 1 中的图像 2,3 LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: 步骤 1 中的图像 3,3
    • Locate the right and left side speaker where the hidden screw is located and remove the rubber piece covering the screw.
  2. LG Tone Pro HBS-760 Speaker  Replacement, Remove Hidden Screw: 步骤 2 中的图像 1,2 LG Tone Pro HBS-760 Speaker  Replacement, Remove Hidden Screw: 步骤 2 中的图像 2,2
    • Using a Philips #00 screwdriver, remove the hidden screws from both sides.
  3. LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: 步骤 3 中的图像 1,3 LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: 步骤 3 中的图像 2,3 LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: 步骤 3 中的图像 3,3
    • Use a guitar pick or any opening tool to pry open the housing for the side you want to replace the speaker.
  4. LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: 步骤 4 中的图像 1,3 LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: 步骤 4 中的图像 2,3 LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: 步骤 4 中的图像 3,3
    • Right side can be de-soldered right away but the left side speaker solder connection to the board is covered by rubber material which needs to be removed first before it can be de-soldered.
  5. LG Tone Pro HBS-760 Speaker  Replacement, Replace Speakers: 步骤 5 中的图像 1,1
    • Once the speakers have been de-soldered, replace with new ones.
结论
2等其他人完成本指南。
Faizan Naveed
于04/12/17注册
3,294 声望
创作了8篇指南
团队
Mobile Device Repair Factory Mobile Device Repair Factory 的会员
Business
1 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 23
总计 1,507
