跳转到主内容
LG Tone Infinim HBS-910 Battery Replacement
你所需要的
  1. LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: 步骤 1 中的图像 1,3 LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: 步骤 1 中的图像 2,3 LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: 步骤 1 中的图像 3,3
    • Battery is on right side of headset.
    • First remove rubber cover on the right side of the headset to uncover the hidden screw.
    • Remove screw using Philips PH00 screwdriver.
  2. LG Tone Infinim HBS-910 Battery Replacement, Disassemble right side.: 步骤 2 中的图像 1,2 LG Tone Infinim HBS-910 Battery Replacement, Disassemble right side.: 步骤 2 中的图像 2,2
    • Use a guitar pick or any opening tool to pry open the right side.
  3. LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: 步骤 3 中的图像 1,3 LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: 步骤 3 中的图像 2,3 LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: 步骤 3 中的图像 3,3
    • Once you have opened the right side up until the speaker end, there will be a hidden screw that needs to be unscrewed before the right side can be completely disassembled.
    • Pry open the speaker back housing with a guitar pick or any opening tool as shown in the picture.
    • Once the speaker back housing is lifted, you will see the screw.
    • Remove the screw and the whole right side will be disassembled.
  4. LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: 步骤 4 中的图像 1,3 LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: 步骤 4 中的图像 2,3 LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: 步骤 4 中的图像 3,3
    • Use a non-metal tool to lift the battery out of place so it will be easy to desolder.
    • Remember the red wire is positive(+) and the black wire is negative(-).
结论
13等其他人完成本指南。
Faizan Naveed
于04/12/17注册
3,294 声望
创作了8篇指南
团队
Mobile Device Repair Factory Mobile Device Repair Factory 的会员
Business
1 名成员
创作了16篇指南
2条评论
Battery model and amps
honda kung - 回复
Hello budy!
Tanks for the guide, i was going crazy looking for that hidden screw!
You might be able to help me. Would you know what i must look for a malfunctioning earbud? My right one suddenly died and im hoping the cord isn't broken and its just some loose weld.
Rafael Zerbini - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 25
总计 11,265
