跳转到主内容
LG Tone Active HBS-850 Speaker Replacement
你所需要的
  1. LG Tone Active HBS-850 Speaker Replacement, Locate Hidden Screw: 步骤 1 中的图像 1,2 LG Tone Active HBS-850 Speaker Replacement, Locate Hidden Screw: 步骤 1 中的图像 2,2
    • Locate the hidden screw as seen in the picture and remove the rubber covering the screw.
  2. LG Tone Active HBS-850 Speaker Replacement, Remove Hidden Screw: 步骤 2 中的图像 1,1
    • Remove hidden screw using a Philips #00 screwdriver.
  3. LG Tone Active HBS-850 Speaker Replacement, Pry Open Speaker Housing: 步骤 3 中的图像 1,2 LG Tone Active HBS-850 Speaker Replacement, Pry Open Speaker Housing: 步骤 3 中的图像 2,2
    • Use a guitar pick or any pry opening tool to gently lift the housing until the speaker end. There is a hidden screw that needs to be removed before the housing can be completely removed.
  4. LG Tone Active HBS-850 Speaker Replacement, Locate Hidden Speaker Screw: 步骤 4 中的图像 1,2 LG Tone Active HBS-850 Speaker Replacement, Locate Hidden Speaker Screw: 步骤 4 中的图像 2,2
    • Gently remove the pointy rubber covering using tweezers where the speaker rests as shown in the picture.
  5. LG Tone Active HBS-850 Speaker Replacement, Remove Hidden Speaker Screw: 步骤 5 中的图像 1,2 LG Tone Active HBS-850 Speaker Replacement, Remove Hidden Speaker Screw: 步骤 5 中的图像 2,2
    • Use a Philips #00 screwdriver to remove the hidden screw.
  6. LG Tone Active HBS-850 Speaker Replacement, Remove Speaker Screw: 步骤 6 中的图像 1,1
    • Remove the screw holding the speaker in place using a Philips #00 screwdriver.
  7. LG Tone Active HBS-850 Speaker Replacement, Desolder Speaker: 步骤 7 中的图像 1,2 LG Tone Active HBS-850 Speaker Replacement, Desolder Speaker: 步骤 7 中的图像 2,2
    • Desolder speaker connection using a soldering iron and replace with new speaker.
结论
2等其他人完成本指南。
Faizan Naveed
于04/12/17注册
3,294 声望
创作了8篇指南
团队
Mobile Device Repair Factory Mobile Device Repair Factory 的会员
Business
1 名成员
创作了16篇指南
4条评论
Do you know of a place to buy a replacement speaker?
James Cimabue - 回复
Excellent instructions and thank you for your time doing this! Can you give a source for the speaker parts other than LG ?
Again thank you
Jim Husselman - 回复
BT Headphone Neckband type with Retractable Earbud (similar contruction ) :: Do you have instructions for repairing loose connection between earbud and wire for model SX-991
Rajesh Narayanan - 回复
Cant find anywhere to buy replacement speakers!
tom - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 21
总计 2,548
