跳转到主内容
LG Thrill 4G SIM/Micro SD Card Replacement
你所需要的
  1. LG Thrill 4G SIM/Micro SD Card Replacement, Back Cover Removal: 步骤 1 中的图像 1,2 LG Thrill 4G SIM/Micro SD Card Replacement, Back Cover Removal: 步骤 1 中的图像 2,2
    • Pry open the back cover by using a fingernail or a plastic opening tool.
    • There is a small notch at the bottom of the cover for easy removal.
  2. LG Thrill 4G SIM/Micro SD Card Replacement, Battery Removal: 步骤 2 中的图像 1,2 LG Thrill 4G SIM/Micro SD Card Replacement, Battery Removal: 步骤 2 中的图像 2,2
    • Remove the battery from the phone.
    • There is a small ledge located at the bottom of the battery for easy removal.
  3. LG Thrill 4G SIM/Micro SD Card Replacement, Screw Removal: 步骤 3 中的图像 1,1
    • Remove the three Philips #00 screws from the bottom of the phone.
    • Two 5.5 mm screws
    • One 4 mm screw
  4. LG Thrill 4G SIM/Micro SD Card Replacement, Speaker Removal: 步骤 4 中的图像 1,2 LG Thrill 4G SIM/Micro SD Card Replacement, Speaker Removal: 步骤 4 中的图像 2,2
    • Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
  5. LG Thrill 4G SIM/Micro SD Card Replacement, Buttons: 步骤 5 中的图像 1,1
    • Remove the three buttons from the side and the top of the phone.
    • Power button
    • Volume button
    • 3D camera button
  6. LG Thrill 4G SIM/Micro SD Card Replacement: 步骤 6 中的图像 1,3 LG Thrill 4G SIM/Micro SD Card Replacement: 步骤 6 中的图像 2,3 LG Thrill 4G SIM/Micro SD Card Replacement: 步骤 6 中的图像 3,3
    • Place the plastic opening tool under the bezel at either bottom corner of the HDMI cover.
    • This loosens both the HDMI and USB covers for easy removal.
    • USB Cover
    • HDMI Cover
  7. LG Thrill 4G SIM/Micro SD Card Replacement: 步骤 7 中的图像 1,1
    • Remove the six Phillips #00 screws within the mid-cover bezel.
  8. LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: 步骤 8 中的图像 1,3 LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: 步骤 8 中的图像 2,3 LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: 步骤 8 中的图像 3,3
    • Utilize a spudger or plastic opening tool and gently disconnect the ribbon cable that is attached to the black micro-SIM card board.
  9. LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: 步骤 9 中的图像 1,3 LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: 步骤 9 中的图像 2,3 LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: 步骤 9 中的图像 3,3
    • Carefully pry the board up to detach it from its place in the phone.
    • Make sure to pry off the small tab connected to the camera unit as well.
结论
另外一个人完成了本指南。
Khbero Baker
于01/19/15注册
128 声望
撰写一个指南
团队
USF Tampa, Team 1-6, Blackwell Winter 2015 USF Tampa, Team 1-6, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S1G6
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 11
总计 594
