跳转到主内容
LG Thrill 4G Motherboard Replacement
你所需要的
  1. LG Thrill 4G Motherboard Replacement, Back Cover Removal: 步骤 1 中的图像 1,2 LG Thrill 4G Motherboard Replacement, Back Cover Removal: 步骤 1 中的图像 2,2
    • Pry open the back cover by using a fingernail or a plastic opening tool.
    • There is a small notch at the bottom of the cover for easy removal.
  2. LG Thrill 4G Motherboard Replacement, Battery Removal: 步骤 2 中的图像 1,2 LG Thrill 4G Motherboard Replacement, Battery Removal: 步骤 2 中的图像 2,2
    • Remove the battery from the phone.
    • There is a small ledge located at the bottom of the battery for easy removal.
  3. LG Thrill 4G Motherboard Replacement, Screw Removal: 步骤 3 中的图像 1,1
    • Remove the three Philips #00 screws from the bottom of the phone.
    • Two 5.5 mm screws
    • One 4 mm screw
  4. LG Thrill 4G Motherboard Replacement, Speaker Removal: 步骤 4 中的图像 1,2 LG Thrill 4G Motherboard Replacement, Speaker Removal: 步骤 4 中的图像 2,2
    • Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
  5. LG Thrill 4G Motherboard Replacement, Buttons: 步骤 5 中的图像 1,1
    • Remove the three buttons from the side and the top of the phone.
    • Power button
    • Volume button
    • 3D camera button
  6. LG Thrill 4G Motherboard Replacement: 步骤 6 中的图像 1,3 LG Thrill 4G Motherboard Replacement: 步骤 6 中的图像 2,3 LG Thrill 4G Motherboard Replacement: 步骤 6 中的图像 3,3
    • Place the plastic opening tool under the bezel at either bottom corner of the HDMI cover.
    • This loosens both the HDMI and USB covers for easy removal.
    • USB Cover
    • HDMI Cover
  7. LG Thrill 4G Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the six Phillips #00 screws within the mid-cover bezel.
  8. LG Thrill 4G Motherboard Replacement, Ribbon Cable Disconnection: 步骤 8 中的图像 1,3 LG Thrill 4G Motherboard Replacement, Ribbon Cable Disconnection: 步骤 8 中的图像 2,3 LG Thrill 4G Motherboard Replacement, Ribbon Cable Disconnection: 步骤 8 中的图像 3,3
    • Utilize a spudger or plastic opening tool and gently disconnect the ribbon cable that is attached to the black micro-SIM card board.
  9. LG Thrill 4G Motherboard Replacement, SD/SIM Card Board Removal: 步骤 9 中的图像 1,3 LG Thrill 4G Motherboard Replacement, SD/SIM Card Board Removal: 步骤 9 中的图像 2,3 LG Thrill 4G Motherboard Replacement, SD/SIM Card Board Removal: 步骤 9 中的图像 3,3
    • Carefully pry the board up to detach it from its place in the phone.
    • Make sure to pry off the small tab connected to the camera unit as well.
  10. LG Thrill 4G Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,2 LG Thrill 4G Motherboard Replacement, Motherboard: 步骤 10 中的图像 2,2
    • Use a plastic opening tool or spudger to gently disconnect the ribbon cables connected to the motherboard.
    • Disconnect the antenna cable from the bottom right corner of the motherboard.
  11. LG Thrill 4G Motherboard Replacement: 步骤 11 中的图像 1,2 LG Thrill 4G Motherboard Replacement: 步骤 11 中的图像 2,2
    • Use a spudger or pair of tweezers to grab the top left corner of the motherboard and gently lift it out, taking care to not damage any of the ribbon cables when removing.
结论
2等其他人完成本指南。
Luis Mena
于01/20/15注册
270 声望
创作了2篇指南
团队
USF Tampa, Team 1-6, Blackwell Winter 2015 USF Tampa, Team 1-6, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S1G6
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 14
总计 497
