跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的LG T310,请使用我们的维修手册
  1. LG T310 Teardown, LG T310 Teardown: 步骤 1 中的图像 1,1
    • Slide back cover down with hand in the direction of the arrow on the cover
    • Gently remove back cover
    • Remove the battery by inserting the plastic opening tool into the groove and gently prying it out
  2. LG T310 Teardown: 步骤 2 中的图像 1,2 LG T310 Teardown: 步骤 2 中的图像 2,2
    • Remove all of the screws on the back of the phone using a Phillips head screw driver
    • Slide out the SIM card from the phone
  3. LG T310 Teardown: 步骤 3 中的图像 1,1
    • Using the plastic opening tool, pry off the shell of the phone, revealing the motherboard
  4. LG T310 Teardown: 步骤 4 中的图像 1,2 LG T310 Teardown: 步骤 4 中的图像 2,2
    • Using the plastic opening tool, gently pry the motherboard out (while doing this be sure not to pull on the mother board as it is attached to the touch screen)
    • Starting at the top left corner of the screen (with phone face down), insert your plastic opening tool and work down the left side.
    • The screen should be loose now making it possible to remove it from the case by hand (try not to touch the actual screen, only the side or back).
    • This completes the tear down of your LG-T310 Cookie
Andrew
于11/07/13注册
116 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,387
