简介
This guide will walk you through the steps of removing the midframe of your LG Sunrise.
你所需要的
步骤 5 Lower Back Plastic Piece
注意:步骤 5-6 源自标记为进行中的 指南。
You will be first removing the two lower screws. This is allow you to remove the lower plastic piece.
Once you have removed all 6 screws. Gently pry all sides of back plastic piece, starting at the bottom. Once you start on the bottom, it will become easier to pry.
即将完成!
结论
另外一个人完成了本指南。
