跳转到主内容
LG Stylo 3 Plus Motherboard Replacement
你所需要的
  1. LG Stylo 3 Plus Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,3 LG Stylo 3 Plus Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,3 LG Stylo 3 Plus Motherboard Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Power off the phone before beginning disassembly.
    • Place the phone face down.
    • Insert a fingernail or a plastic opening tool into the gap on the side of the phone.
    • Carefully slide your finger or the tool throughout the edge of the phone to ease the back case off.
  2. LG Stylo 3 Plus Motherboard Replacement, Battery: 步骤 2 中的图像 1,3 LG Stylo 3 Plus Motherboard Replacement, Battery: 步骤 2 中的图像 2,3 LG Stylo 3 Plus Motherboard Replacement, Battery: 步骤 2 中的图像 3,3
    • Place the back cover off to the side.
    • Insert the opening tool into the small gap below the battery.
    • Carefully pop the battery out to prevent damage.
  3. LG Stylo 3 Plus Motherboard Replacement, Rear Camera: 步骤 3 中的图像 1,3 LG Stylo 3 Plus Motherboard Replacement, Rear Camera: 步骤 3 中的图像 2,3 LG Stylo 3 Plus Motherboard Replacement, Rear Camera: 步骤 3 中的图像 3,3
    • Remove the twelve 4mm screws using the Phillips #000 screwdriver.
    • Use the plastic opening tool to remove the inner case.
    • Carefully remove the inner case.
  4. LG Stylo 3 Plus Motherboard Replacement: 步骤 4 中的图像 1,2 LG Stylo 3 Plus Motherboard Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use your fingernail or the plastic opening tool to flip the flex cable.
    • Use the precision tweezers to carefully grasp and pull out the camera.
  5. LG Stylo 3 Plus Motherboard Replacement, Front Camera: 步骤 5 中的图像 1,2 LG Stylo 3 Plus Motherboard Replacement, Front Camera: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Carefully flip open the flex cable box with the plastic opening tool.
    • Using precision tweezers, carefully lift the front camera off the device.
  6. LG Stylo 3 Plus Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,3 LG Stylo 3 Plus Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,3 LG Stylo 3 Plus Motherboard Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Gently flip open the flex cable box using a blue plastic opening tool.
    • Carefully remove the motherboard with your hands or a blue plastic opening tool.
    • Make sure all parts are secure while taking out motherboard.
结论
4等其他人完成本指南。
团队
UMass Dartmouth, Team S2-G6, Peak Fall 2018 UMass Dartmouth, Team S2-G6, Peak Fall 2018 的会员
UMASSD-PEAK-F18S2G6
3 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 3,404
