跳转到主内容
LG Stylo 2 Plus Speaker Replacement
你所需要的
  1. LG Stylo 2 Plus Speaker Replacement, Rear Case: 步骤 1 中的图像 1,3 LG Stylo 2 Plus Speaker Replacement, Rear Case: 步骤 1 中的图像 2,3 LG Stylo 2 Plus Speaker Replacement, Rear Case: 步骤 1 中的图像 3,3
    • To remove the rear case of the phone, insert the spudger into the opening on the back of the case.
    • With the spudger parallel to the frame of the phone, slide it along the edge, forcing the casing to pop off.
  2. LG Stylo 2 Plus Speaker Replacement, Battery: 步骤 2 中的图像 1,3 LG Stylo 2 Plus Speaker Replacement, Battery: 步骤 2 中的图像 2,3 LG Stylo 2 Plus Speaker Replacement, Battery: 步骤 2 中的图像 3,3
    • To remove the battery, insert your fingernail or the flat end of the spudger into the dimple at the bottom of the battery and lift upwards.
    • Firmly grasp the battery and remove from the phone.
  3. LG Stylo 2 Plus Speaker Replacement, Speaker: 步骤 3 中的图像 1,2 LG Stylo 2 Plus Speaker Replacement, Speaker: 步骤 3 中的图像 2,2
    • Remove the cover from the phone in order to access the speaker.
    • Using the JIS #000 screwdriver, remove the four 4mm screws around the base of the mid-frame.
  4. LG Stylo 2 Plus Speaker Replacement: 步骤 4 中的图像 1,2 LG Stylo 2 Plus Speaker Replacement: 步骤 4 中的图像 2,2
    • Insert the metal spudger in the dimple at the base of the mid-frame.
    • Pry upward, removing bottom section of the mid-frame from the phone.
  5. LG Stylo 2 Plus Speaker Replacement: 步骤 5 中的图像 1,3 LG Stylo 2 Plus Speaker Replacement: 步骤 5 中的图像 2,3 LG Stylo 2 Plus Speaker Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Flip the bottom piece of the mid-frame over to show the speaker in the bottom right corner.
    • Using the tweezers, peel back the rubber resting on top of the speaker.
    • Still using the tweezers, grasp the speaker unit and remove it from the mid-frame.
结论
另外一个人完成了本指南。
Noah Kehm
于04/22/19注册
241 声望
创作了3篇指南
团队
UW Tacoma, Team S1-G3, Cardinal Spring 2019 UW Tacoma, Team S1-G3, Cardinal Spring 2019 的会员
UWT-CARDINAL-S19S1G3
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 8
总计 475
