跳转到主内容
LG Spectrum Sim/SD Port Replacement
你所需要的
  1. LG Spectrum Sim/SD Port Replacement, Battery: 步骤 1 中的图像 1,2 LG Spectrum Sim/SD Port Replacement, Battery: 步骤 1 中的图像 2,2
    • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
  2. LG Spectrum Sim/SD Port Replacement: 步骤 2 中的图像 1,1
    • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
  3. LG Spectrum Sim/SD Port Replacement, Sim/SD Port: 步骤 3 中的图像 1,2 LG Spectrum Sim/SD Port Replacement, Sim/SD Port: 步骤 3 中的图像 2,2
    • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
    • Use the magnetic mat to keep the screws in one place.
  4. LG Spectrum Sim/SD Port Replacement: 步骤 4 中的图像 1,1
    • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
  5. LG Spectrum Sim/SD Port Replacement: 步骤 5 中的图像 1,1
    • Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
  6. LG Spectrum Sim/SD Port Replacement: 步骤 6 中的图像 1,1
    • Hook the plastic opening tool underneath the plate and gently lift it up.
  7. LG Spectrum Sim/SD Port Replacement: 步骤 7 中的图像 1,1
    • Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
结论
Aiman Sallam
于02/10/16注册
506 声望
创作了5篇指南
团队
USF Tampa, Team 1-4, Sullivan Spring 2016 USF Tampa, Team 1-4, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S1G4
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 298
