当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the phone's back cover by placing your thumb the above charging port, located at the bottom of the phone, and sliding the back cover upward.
Gently pry the battery out of the phone with the spudger.
Unscrew the 5 #1 5mm screws.
Lift the inner shell from the phone.
Unscrew two 2mm #00 screws located behind the white serial code sticker.
Disconnect the ribbon found in the middle of the phone
Gently pull the ribbon out of the way.
Slide open the phone, revealing the QWERTY keyboard.
Carefully push the mother board through by pressing into the keyboard.
The mother board will fall out of the back along with the silicon keyboard pad.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与7其他贡献者
于01/14/14注册
134 声望
撰写一个指南
徽章: 5
+ 2更多徽章
CPSU-FORTE-W14S17G2
5 名成员
创作了12篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 728
