跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide explains how to replace the motherboard of an LG Rumor Touch, a touch screen phone.
  1. Remove the phone's back cover by placing your thumb the above charging port, located at the bottom of the phone, and sliding the back cover upward.
    • Remove the phone's back cover by placing your thumb the above charging port, located at the bottom of the phone, and sliding the back cover upward.
  2. Gently pry the battery out of the phone with the spudger. Gently pry the battery out of the phone with the spudger.
    • Gently pry the battery out of the phone with the spudger.
  3. Unscrew the 5 #1 5mm screws.
    • Unscrew the 5 #1 5mm screws.
  4. LCD iPhone 屏幕维修套装
    预算选项,涵盖在我们的终身保修中。
    购买套装
    LCD iPhone 屏幕维修套装
    削减维修成本,而不是质量。
    购买套装
  5. Lift the inner shell from the phone.
    • Lift the inner shell from the phone.
  6. Unscrew two 2mm #00 screws located behind the white serial code sticker.
    • Unscrew two 2mm #00 screws located behind the white serial code sticker.
  7. Disconnect the ribbon found in the middle of the phone
    • Disconnect the ribbon found in the middle of the phone
    • Gently pull the ribbon out of the way.
  8. Slide open the phone, revealing the QWERTY keyboard. Slide open the phone, revealing the QWERTY keyboard.
    • Slide open the phone, revealing the QWERTY keyboard.
  9. Carefully push the mother board through by pressing into the keyboard. Carefully push the mother board through by pressing into the keyboard.
    • Carefully push the mother board through by pressing into the keyboard.
  10. The mother board will fall out of the back along with the silicon keyboard pad.
    • The mother board will fall out of the back along with the silicon keyboard pad.
结论
Jose Rivas
于2014年01月14日注册
119 信誉积分
撰写一个指南
团队
Cal Poly, Team 17-2, Forte Winter 2014 Cal Poly, Team 17-2, Forte Winter 2014 的会员
CPSU-FORTE-W14S17G2
5 名成员
创作了12篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 541
