跳转到主内容
LG Risio Rear-Facing Camera Replacement
你所需要的
  1. LG Risio Rear-Facing Camera Replacement, Back Panel: 步骤 1 中的图像 1,2 LG Risio Rear-Facing Camera Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. LG Risio Rear-Facing Camera Replacement, Battery: 步骤 2 中的图像 1,1
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. LG Risio Rear-Facing Camera Replacement, Midframe: 步骤 3 中的图像 1,1
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. LG Risio Rear-Facing Camera Replacement: 步骤 4 中的图像 1,2 LG Risio Rear-Facing Camera Replacement: 步骤 4 中的图像 2,2
    • Remove the eight Phillips #0 screws from the internal support frame.
  5. LG Risio Rear-Facing Camera Replacement: 步骤 5 中的图像 1,3 LG Risio Rear-Facing Camera Replacement: 步骤 5 中的图像 2,3 LG Risio Rear-Facing Camera Replacement: 步骤 5 中的图像 3,3
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  6. LG Risio Rear-Facing Camera Replacement: 步骤 6 中的图像 1,1
    • Using your hand, pick up the midframe to separate it from the phone.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 6
总计 121
