简介
If there are a lot of issues on the phone such as the blue screen, the screen not turning on, or the headphone jack not working properly, it may be the motherboard. Use this guide to replace the motherboard to fix the issues listed above.
  1. Use a plastic opening tool to seperate the back panel from the device. Remove the back panel.
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. Place your thumb along the bottom of the battery and pry upwards to remove.
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Remove the eight Phillips #0 screws from the internal support frame. Remove the eight Phillips #0 screws from the internal support frame.
    • Remove the eight Phillips #0 screws from the internal support frame.
  6. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  7. Using your hand, pick up the midframe to  separate it from the phone.
    • Using your hand, pick up the midframe to separate it from the phone.
    • If the midframe does not want to lift off, go back and repeat step 6.
  8. Detach the screen connector from the motherboard by putting your thumb underneath it and lifting up. The screen connector is the part that has P5 written on it.
    • Detach the screen connector from the motherboard by putting your thumb underneath it and lifting up.
    • The screen connector is the part that has P5 written on it.
  9. On the side with the screen connector, pull the two tabs away from the device.
    • On the side with the screen connector, pull the two tabs away from the device.
    • Use the plastic opening tool to lift the motherboard starting on the bottom right corner and pulling upwards.
结论
另外一个人完成了本指南。
Erika Heppner
于2018年02月21日注册
307 信誉积分
创作了4篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 5
过去的30天: 7
总计 108
