跳转到主内容
LG Refrigerator Fresh Food Thermistor Test and Replacement
你所需要的
  1. LG Refrigerator Fresh Food Thermistor Test and Replacement, Unplug your refrigerator: 步骤 1 中的图像 1,1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Fresh Food Thermistor Test and Replacement, Open the doors: 步骤 2 中的图像 1,3 LG Refrigerator Fresh Food Thermistor Test and Replacement, Open the doors: 步骤 2 中的图像 2,3 LG Refrigerator Fresh Food Thermistor Test and Replacement, Open the doors: 步骤 2 中的图像 3,3
    • Open both refrigerator doors fully.
  3. LG Refrigerator Fresh Food Thermistor Test and Replacement, Remove the shelves: 步骤 3 中的图像 1,3 LG Refrigerator Fresh Food Thermistor Test and Replacement, Remove the shelves: 步骤 3 中的图像 2,3 LG Refrigerator Fresh Food Thermistor Test and Replacement, Remove the shelves: 步骤 3 中的图像 3,3
    • Lift up the front edge of the shelf to release it.
    • Unhook the shelf and remove it.
    • Repeat the last two steps for each shelf you wish to remove.
  4. LG Refrigerator Fresh Food Thermistor Test and Replacement, Unfasten the control board cover: 步骤 4 中的图像 1,1
    • Use a Phillips screwdriver to remove the screws securing the control board cover.
  5. LG Refrigerator Fresh Food Thermistor Test and Replacement, Remove the control board cover: 步骤 5 中的图像 1,3 LG Refrigerator Fresh Food Thermistor Test and Replacement, Remove the control board cover: 步骤 5 中的图像 2,3 LG Refrigerator Fresh Food Thermistor Test and Replacement, Remove the control board cover: 步骤 5 中的图像 3,3
    • Tilt the top edge of the cover toward you and lift it off.
  6. LG Refrigerator Fresh Food Thermistor Test and Replacement, Locate thermistor connector: 步骤 6 中的图像 1,1
    • Locate connector 7 (Con 7) on the control board
  7. LG Refrigerator Fresh Food Thermistor Test and Replacement: 步骤 7 中的图像 1,3 LG Refrigerator Fresh Food Thermistor Test and Replacement: 步骤 7 中的图像 2,3 LG Refrigerator Fresh Food Thermistor Test and Replacement: 步骤 7 中的图像 3,3
    • Release the wiring harness for Connector 7 from the harness hooks.
    • Disconnect Con 7.
  8. LG Refrigerator Fresh Food Thermistor Test and Replacement, Test thermistor circuit: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    Digital Multimeter
    $59.95
    • Measure the resistance between the two white wires as shown in this document.
    • Use a multimeter set to the ohms (Ω) setting.
    • Gently put the probes into the connector holes that correspond to the white wires. Alternatively, you can use sharp insulation piercing probes on the white wires.
    • Measure the resistance of the thermistor.
    • If the measurement is neither open (OL) nor shorted (less than 1Ω), measure the temperature in the fresh food compartment. Compare these figures to this chart. If it isn't in spec, go to the next step.
    • The resistance of the thermistor should be about 11kΩ at room temperature.
  9. LG Refrigerator Fresh Food Thermistor Test and Replacement, Access the thermistor.: 步骤 9 中的图像 1,3 LG Refrigerator Fresh Food Thermistor Test and Replacement, Access the thermistor.: 步骤 9 中的图像 2,3 LG Refrigerator Fresh Food Thermistor Test and Replacement, Access the thermistor.: 步骤 9 中的图像 3,3
    • Pry down the thermistor grille/holder with a spudger or small flat-blade screwdriver.
  10. LG Refrigerator Fresh Food Thermistor Test and Replacement, Free the thermistor: 步骤 10 中的图像 1,3 LG Refrigerator Fresh Food Thermistor Test and Replacement, Free the thermistor: 步骤 10 中的图像 2,3 LG Refrigerator Fresh Food Thermistor Test and Replacement, Free the thermistor: 步骤 10 中的图像 3,3
    • Gently use a pair of long-nose pliers to pull the thermistor down from its holder.
    • Be very careful with this action, as the leads to the thermistor are short and can be easily damaged.
    • If the measurement at the control board was out of spec or showed open (infinite resistance) or short (near zero resistance), check the resistance at the thermistor itself.
    • Disconnect the thermistor from the wiring harness. You will likely have to cut one or both of the leads, unless there is a connector near the thermistor.
    • If the thermistor tests okay, the problem is in the wiring harness. You can inspect the accessible parts of the harness for faults. If the fault is not accessible, the wiring harness is foamed in and can't be repaired. Recycle the refrigerator.
结论
另外一个人完成了本指南。
Bill Gilbert
于06/30/22注册
38,494 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,580篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 72
总计 1,140
