跳转到主内容
LG Rebel Screen Replacement
你所需要的
  1. LG Rebel Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Place the plastic opening tool into the indent on the side of the phone and lift the back off the device.
  2. LG Rebel Screen Replacement: 步骤 2 中的图像 1,1
    • Put the plastic opening tool in at a downward angle and push it up so that the back pops off.
  3. LG Rebel Screen Replacement: 步骤 3 中的图像 1,3 LG Rebel Screen Replacement: 步骤 3 中的图像 2,3 LG Rebel Screen Replacement: 步骤 3 中的图像 3,3
    • Insert the spudger into the small groove under one of the two black pieces.
  4. LG Rebel Screen Replacement: 步骤 4 中的图像 1,2 LG Rebel Screen Replacement: 步骤 4 中的图像 2,2
    • Using either your finger or the spudger, gently lift the metal clasps until they are no longer connected to the back of the phone.
  5. LG Rebel Screen Replacement: 步骤 5 中的图像 1,2 LG Rebel Screen Replacement: 步骤 5 中的图像 2,2
    • Using the metal spudger, push gently under the edge of the screen. You will hear the sound of the screen disconnecting from the glue.
    • Run the metal spudger around the entire perimeter of the phone , making sure to fully disconnect it from the glue.
  6. LG Rebel Screen Replacement: 步骤 6 中的图像 1,1
    • Place suction cup on the screen.
    • Gently pull the screen up until it is completely disconnected from the phone.
结论
13等其他人完成本指南。
devan morales
于02/08/18注册
561 声望
撰写一个指南
团队
3条评论
Hey! Very helpful guide. I was just wondering if this works with replacing the digitizer and the screen, or is it just the screen? email ellym54@gmail.com, I would really appreciate the help!
Elly Murray - 回复
How do you know if you need to replace the digitizer as well? This Lg Rebel4 was dropped & screen cracked in 2 places however everything still works fine? Im not sure what a digitizer does though. Please help me so i understand because i dont want to mess this up.
Thanks guys
Blackhatchic1@gmail.com
BlackHat Chic - 回复
This is just to replace the glass panel over the actual display/digitizer, is it not?
If this is right, why does one need tom remove the back of the case and “undo the metal clips”?
What about gluing the new screen in? It DOES need glue, does it not? Otherwise, what seals it from the environment?
Mark Wallner - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 33
总计 12,291
