跳转到主内容
LG Rebel Rear Camera Replacement
你所需要的
  1. LG Rebel Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 1,2 LG Rebel Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 2,2
    • Turn the phone on its side and locate the small groove.
    • Use the plastic opening tool to take the back cover off of the phone.
  2. LG Rebel Rear Camera Replacement: 步骤 2 中的图像 1,3 LG Rebel Rear Camera Replacement: 步骤 2 中的图像 2,3 LG Rebel Rear Camera Replacement: 步骤 2 中的图像 3,3
    • Locate the small groove on the back of the phone near the bottom.
    • Use the metal spudger to pop open the black plastic covering.
    • Remove black plastic covering.
  3. LG Rebel Rear Camera Replacement: 步骤 3 中的图像 1,2 LG Rebel Rear Camera Replacement: 步骤 3 中的图像 2,2
    • Use the metal spudger to pop up the black plastic covering near top of phone.
    • Remove the black plastic covering.
  4. LG Rebel Rear Camera Replacement: 步骤 4 中的图像 1,3 LG Rebel Rear Camera Replacement: 步骤 4 中的图像 2,3 LG Rebel Rear Camera Replacement: 步骤 4 中的图像 3,3
    • Locate the connective pieces on the back of the phone.
    • Use the metal spudger to disconnect both of the connective pieces from the back.
  5. LG Rebel Rear Camera Replacement: 步骤 5 中的图像 1,3 LG Rebel Rear Camera Replacement: 步骤 5 中的图像 2,3 LG Rebel Rear Camera Replacement: 步骤 5 中的图像 3,3
    • Flip the phone over so the screen is facing up.
    • Slide the metal spudger around the perimeter of the phone until the entire seal has been broken.
    • Use the small suction cup to remove the screen.
  6. LG Rebel Rear Camera Replacement: 步骤 6 中的图像 1,2 LG Rebel Rear Camera Replacement: 步骤 6 中的图像 2,2
    • Locate the black bumper at the bottom of the front of the phone.
    • Use the metal spudger to slide the bumper out.
  7. LG Rebel Rear Camera Replacement: 步骤 7 中的图像 1,3 LG Rebel Rear Camera Replacement: 步骤 7 中的图像 2,3 LG Rebel Rear Camera Replacement: 步骤 7 中的图像 3,3
    • Use the metal spudger to carefully loosen the motherboard from the body of the phone.
    • Slowly slide the motherboard out of the body of the phone.
    • Remove the motherboard.
  8. LG Rebel Rear Camera Replacement: 步骤 8 中的图像 1,2 LG Rebel Rear Camera Replacement: 步骤 8 中的图像 2,2
    • Locate the rear camera on the motherboard.
    • Use the metal spudger to disconnect the connective piece at the base of the camera.
    • Remove the camera.
结论
另外一个人完成了本指南。
Emma Johnson
于02/08/18注册
184 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 501
