跳转到主内容
LG Rebel Front Camera Replacement
你所需要的
  1. LG Rebel Front Camera Replacement, Front Camera: 步骤 1 中的图像 1,3 LG Rebel Front Camera Replacement, Front Camera: 步骤 1 中的图像 2,3 LG Rebel Front Camera Replacement, Front Camera: 步骤 1 中的图像 3,3
    • Turn phone over to its front side.
    • Use a spudger to begin removing the screen by the right hand corner. Begin to move the tool around the edges of the screen.
  2. LG Rebel Front Camera Replacement: 步骤 2 中的图像 1,3 LG Rebel Front Camera Replacement: 步骤 2 中的图像 2,3 LG Rebel Front Camera Replacement: 步骤 2 中的图像 3,3
    • Once you have loosened the grip around the edges, pop off the screen using a suction cup.
    • Once the front screen is removed, place the phone on its side and find the groove located on the side.
    • Use the plastic opening tool to pop open the black plastic covering.
    • Remove black plastic cover.
  3. LG Rebel Front Camera Replacement: 步骤 3 中的图像 1,3 LG Rebel Front Camera Replacement: 步骤 3 中的图像 2,3 LG Rebel Front Camera Replacement: 步骤 3 中的图像 3,3
    • Locate the small groove on the back of the phone near the bottom.
    • Use the metal spudger to pop open the black plastic covering.
    • Remove black plastic covering.
  4. LG Rebel Front Camera Replacement: 步骤 4 中的图像 1,2 LG Rebel Front Camera Replacement: 步骤 4 中的图像 2,2
    • Use the metal spudger to pop up the black plastic covering near top of phone.
    • Remove the black plastic covering.
  5. LG Rebel Front Camera Replacement: 步骤 5 中的图像 1,3 LG Rebel Front Camera Replacement: 步骤 5 中的图像 2,3 LG Rebel Front Camera Replacement: 步骤 5 中的图像 3,3
    • Remove the motherboard with a spudger.
    • Slowly begin to lift motherboard with your hand carefully.
    • Once the motherboard is completely off, set the phone to the side and focus on the small black box with a square tail (which is the front camera).
  6. LG Rebel Front Camera Replacement: 步骤 6 中的图像 1,2 LG Rebel Front Camera Replacement: 步骤 6 中的图像 2,2
    • Remove the front camera by its tail with a spudger.
结论
另外一个人完成了本指南。
Lesley Sigaran
于02/08/18注册
145 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 446
