跳转到主内容
LG Rebel 4 LTE Disassembly
你所需要的
  1. LG Rebel 4 LTE Disassembly, Remove the Cover: 步骤 1 中的图像 1,2 LG Rebel 4 LTE Disassembly, Remove the Cover: 步骤 1 中的图像 2,2
    • Locate the indent on the back left side of the phone.
    • Insert the opening tool into the indent and pry until it pops.
    • Remove the backing.
  2. LG Rebel 4 LTE Disassembly, Remove Internal Components: 步骤 2 中的图像 1,3 LG Rebel 4 LTE Disassembly, Remove Internal Components: 步骤 2 中的图像 2,3 LG Rebel 4 LTE Disassembly, Remove Internal Components: 步骤 2 中的图像 3,3
    • Use the spudger to pry the battery out.
    • If installed, pop out the SD/TF card by gently pressing in and releasing the SD card. Not pictured, Located above the Sims card (See Below).
    • Use your fingers to remove the sim card.
  3. LG Rebel 4 LTE Disassembly, Remove Screws: 步骤 3 中的图像 1,3 LG Rebel 4 LTE Disassembly, Remove Screws: 步骤 3 中的图像 2,3 LG Rebel 4 LTE Disassembly, Remove Screws: 步骤 3 中的图像 3,3
    • Using the #000 Phillips screwdriver, remove all the screws (as seen in the photo).
    • There should be 12 screws in total.
    • Don't lose the screws!
  4. LG Rebel 4 LTE Disassembly, Remove Charging Port Cover: 步骤 4 中的图像 1,2 LG Rebel 4 LTE Disassembly, Remove Charging Port Cover: 步骤 4 中的图像 2,2
    • Use the spudger to carefully pry the cover around the charging port.
  5. LG Rebel 4 LTE Disassembly, Remove the Screen: 步骤 5 中的图像 1,3 LG Rebel 4 LTE Disassembly, Remove the Screen: 步骤 5 中的图像 2,3 LG Rebel 4 LTE Disassembly, Remove the Screen: 步骤 5 中的图像 3,3
    • Rotate the phone (view picture) to reveal the top corner of the phone.
    • Using a opening pick, pry in between the glass screen and the framing.
  6. LG Rebel 4 LTE Disassembly, Remove the Motherboard: 步骤 6 中的图像 1,3 LG Rebel 4 LTE Disassembly, Remove the Motherboard: 步骤 6 中的图像 2,3 LG Rebel 4 LTE Disassembly, Remove the Motherboard: 步骤 6 中的图像 3,3
    • Pry from the top and bottom of the screen with the (refer to photo) opening pick to release the tabs holding the motherboard to the phone.
    • Do not let the main camera fall out while removing the mother board.
  7. LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: 步骤 7 中的图像 1,3 LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: 步骤 7 中的图像 2,3 LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: 步骤 7 中的图像 3,3
    • On the bottom right of the phone, locate a cable that holds the motherboard to the phone.
    • Disconnect the cable by gently pulling up on the component with your fingers.
    • Do not use a prying tool or screwdriver to disconnect the cable.
  8. LG Rebel 4 LTE Disassembly, Remove the Camera: 步骤 8 中的图像 1,3 LG Rebel 4 LTE Disassembly, Remove the Camera: 步骤 8 中的图像 2,3 LG Rebel 4 LTE Disassembly, Remove the Camera: 步骤 8 中的图像 3,3
    • Separate the camera from the magnet by gently pulling up.
  9. LG Rebel 4 LTE Disassembly, Disassembly Complete: 步骤 9 中的图像 1,1
    • Congratulations. You've successfully disassembled your device.
    • To reassemble the device, follow these steps in reverse order. (Begin with step 8, continuining until you end on step 1.
    • When reassembling, make sure that each component snaps tightly to the phone before moving to the next step.
结论
JCJR
于06/23/23注册
169 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 221
