跳转到主内容
LG Realm Plastic Midframe Replacement
你所需要的
  1. LG Realm Plastic Midframe Replacement, Battery: 步骤 1 中的图像 1,2 LG Realm Plastic Midframe Replacement, Battery: 步骤 1 中的图像 2,2
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
  2. LG Realm Plastic Midframe Replacement: 步骤 2 中的图像 1,1
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
  3. LG Realm Plastic Midframe Replacement, Plastic Midframe: 步骤 3 中的图像 1,2 LG Realm Plastic Midframe Replacement, Plastic Midframe: 步骤 3 中的图像 2,2
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
  4. LG Realm Plastic Midframe Replacement: 步骤 4 中的图像 1,1
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
结论
5等其他人完成本指南。
Ryan St Martin
于03/05/16注册
770 声望
创作了4篇指南
团队
Marist, Team 1-5, Laflen Spring 2016 Marist, Team 1-5, Laflen Spring 2016 的会员
MARS-LAFLEN-S16S1G5
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 312
