跳转到主内容
LG Realm Motherboard Replacement
你所需要的
  1. LG Realm Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 LG Realm Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
  2. LG Realm Motherboard Replacement: 步骤 2 中的图像 1,1
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
  3. LG Realm Motherboard Replacement, Plastic Midframe: 步骤 3 中的图像 1,2 LG Realm Motherboard Replacement, Plastic Midframe: 步骤 3 中的图像 2,2
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
  4. LG Realm Motherboard Replacement: 步骤 4 中的图像 1,1
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
  5. LG Realm Motherboard Replacement, Rear Facing Camera: 步骤 5 中的图像 1,1
    • Locate the rear facing camera.
    • Using the plastic opening tool, pry apart the cable from where it connects to the phone.
  6. LG Realm Motherboard Replacement: 步骤 6 中的图像 1,1
    • After removing the ribbon cable, the camera should be easy to remove with your fingers. Remove the rear facing camera.
  7. LG Realm Motherboard Replacement, Front Facing Camera: 步骤 7 中的图像 1,1
    • Locate the front facing camera in the top left hand corner of the motherboard. Using the plastic opening tool, separate the ribbon cable from the phone.
  8. LG Realm Motherboard Replacement: 步骤 8 中的图像 1,1
    • After removing this ribbon cable, you will be able to easily remove the front facing camera with your fingers.
  9. LG Realm Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,1
    • Locate where the motherboard connects to the orange sisterboard. Using the plastic opening tool, disconnect the connection between the phone and the orange ribbon cable.
  10. LG Realm Motherboard Replacement: 步骤 10 中的图像 1,2 LG Realm Motherboard Replacement: 步骤 10 中的图像 2,2
    • Locate the ribbon cables in the top right corner of the motherboard. Using the plastic opening tool, remove the ribbon cables from phone.
  11. LG Realm Motherboard Replacement: 步骤 11 中的图像 1,1
    • Using the plastic opening tool, disconnect the ribbon cable that connects the antenna to the motherboard.
  12. LG Realm Motherboard Replacement: 步骤 12 中的图像 1,1
    • Using the plastic opening tool, carefully remove the motherboard from the phone.
结论
4等其他人完成本指南。
Ryan St Martin
于03/05/16注册
785 声望
创作了4篇指南
团队
Marist, Team 1-5, Laflen Spring 2016 Marist, Team 1-5, Laflen Spring 2016 的会员
MARS-LAFLEN-S16S1G5
2 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 1,305
