跳转到主内容
LG Realm Front Facing Camera Replacement
你所需要的
  1. LG Realm Front Facing Camera Replacement, Battery: 步骤 1 中的图像 1,2 LG Realm Front Facing Camera Replacement, Battery: 步骤 1 中的图像 2,2
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
  2. LG Realm Front Facing Camera Replacement: 步骤 2 中的图像 1,1
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
  3. LG Realm Front Facing Camera Replacement, Plastic Midframe: 步骤 3 中的图像 1,2 LG Realm Front Facing Camera Replacement, Plastic Midframe: 步骤 3 中的图像 2,2
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
  4. LG Realm Front Facing Camera Replacement: 步骤 4 中的图像 1,1
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
  5. LG Realm Front Facing Camera Replacement, Front Facing Camera: 步骤 5 中的图像 1,1
    • Locate the front facing camera in the top left hand corner of the motherboard. Using the plastic opening tool, separate the ribbon cable from the phone.
  6. LG Realm Front Facing Camera Replacement: 步骤 6 中的图像 1,1
    • After removing this ribbon cable, you will be able to easily remove the front facing camera with your fingers.
结论
4等其他人完成本指南。
Ryan St Martin
于03/05/16注册
770 声望
创作了4篇指南
团队
Marist, Team 1-5, Laflen Spring 2016 Marist, Team 1-5, Laflen Spring 2016 的会员
MARS-LAFLEN-S16S1G5
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 411
