简介
This guide will walk you through the process of replacing a screen in an LG Phoenix 2. This guide should be used if the screen is cracked. The guide should also be used if the screen does not respond to your touch.
你所需要的
Place a fingernail in the notch at the bottom edge of the phone.
Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
Locate the SIM card in the top right corner on the back of the phone.
Remove the SIM card by pushing it with your thumb from left to right.
6等其他人完成本指南。
2条评论
“Works for the Phoenix 3 as well but I wouldn’t try taking out the rear facing camera. You shouldn’t have to either way” -dtcarani
Thank you dtcarani it absolutely does work for the Phoenix 3.
And, I did not need to remove the rear facing camera.
