跳转到主内容
LG Optimus V Speaker Replacement
你所需要的
  1. LG Optimus V Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the LG Optimus V over, so that the back cover is facing upward.
  2. LG Optimus V Speaker Replacement: 步骤 2 中的图像 1,1
    • Locate the opening above the camera.
    • Use a spudger to detach the back cover.
  3. LG Optimus V Speaker Replacement: 步骤 3 中的图像 1,3 LG Optimus V Speaker Replacement: 步骤 3 中的图像 2,3 LG Optimus V Speaker Replacement: 步骤 3 中的图像 3,3
    • Gently remove the battery with your spudger.
  4. LG Optimus V Speaker Replacement, Camera: 步骤 4 中的图像 1,2 LG Optimus V Speaker Replacement, Camera: 步骤 4 中的图像 2,2
    • Remove the six screws on the silver casing.
    • Use the plastic opening tool to remove the silver casing.
  5. LG Optimus V Speaker Replacement: 步骤 5 中的图像 1,3 LG Optimus V Speaker Replacement: 步骤 5 中的图像 2,3 LG Optimus V Speaker Replacement: 步骤 5 中的图像 3,3
    • Use a plastic opening tool to remove each area holding the parts together.
  6. LG Optimus V Speaker Replacement: 步骤 6 中的图像 1,2 LG Optimus V Speaker Replacement: 步骤 6 中的图像 2,2
    • Use a plastic opening tool to remove the small black and yellow piece that reads Y3114C.
    • Use a plastic opening tool to pry off the camera.
  7. LG Optimus V Speaker Replacement, Speaker: 步骤 7 中的图像 1,1
    • This is the area that holds the speaker.
  8. LG Optimus V Speaker Replacement: 步骤 8 中的图像 1,2 LG Optimus V Speaker Replacement: 步骤 8 中的图像 2,2
    • To fix the speaker, use a soldering iron to heat up the two areas where the wires connect to the motherboard. Then, remove the old speaker and replace it with a new one by soldering it back onto the same areas.
    • Once you’re done, your speaker should be working properly again.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 1-2, Shastany Fall 2013 UMass Dartmouth, Team 1-2, Shastany Fall 2013 的会员
UMASSD-SHASTANY-F13S1G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 796
